tried everthing i culd think of to het my n80 to link to my n80 to my wireless network, can't think how to get it to work, im sure i've done it all right just keep getting the message "no reply from gateway" any suggestions.
>>and<<
can someone tell me how to check my firmware version
On your router see if you have MAC filtering enabled, if you do either enter the mac address of your phone or diasble it
To find the Mac Address. enter *#62209526#
To Find your firmware version enter *#0000#
mac filtering is not on all i keep getting is the message no rpely form gateway anyone else having this problem any help would be gratefully appreciated
Are you then able to OK this error and then a white screen appears with a mouse cursor? If so then try and browse the web (e.g. go to a web address).
I *always* get an error every time I open the browser (usually "Unable to perform operation"😉, but I just OK it and then am able to browse the web as normal. I assume this is just a bug that will be fixed in a future firmware update.
Well, just check in your router whether, you have enabled DHCP server...
