my phone wont allow me to install anymore applications because my phone memory is full but i select hard drive when installing, i noticed every time i installed an application my phone memory went lower every time, also i havent saved anything onto my phone memory but it is full with something and i cant find any files in the phone memory, can anyone please help me, thx
khuram
Hi
You need to open your file manager and go to the folder marked "Installed Files"
In here is where the SIS & Jar files go before they are installed. They are not deleted after install. You just need to go in there and delete them. It will NOT affect anything already installed.
installed files folder in phone memory is empty. but my phone memory says i have 8694kb of messages even though i dont have any saved and i cant seemed to find any at all. nothing to delete on phone memory.
:con?
Have you check you haven't got a big bunch of emails sitting somewhere?
The other one to check is images from the camera.
In C:/Nokia/Images I think.
nope nothing, all empty, i am trying to get a file explorer installed but its makin uninstall loads of apps. keep comin up with no memory.
Use the built in file manager (under Toos or maybe Office folder).
have you received any files by bluetooth ? try deleting a few few files in your inbox... i had the same problem and it worked for me.
