I can't get Nokia PC Suite 6.80.22 to detect my phone or USB cable. The cable worked with my 7250i using the driver CD that came with it, but the drivers must be outdated for this new fone...
I tried the Nokia Connectivity Cable Driver 6.80.5.1 thing but no luck. Can someone run me through all the steps of getting this to work?
I'm running a AMD Athlon64 X2 3800 with 2GB RAM and Windows XP Professional SP2 and USB 2.0.
OpethOrchid wrote:I can't get Nokia PC Suite 6.80.22 to detect my phone or USB cable. The cable worked with my 7250i using the driver CD that came with it, but the drivers must be outdated for this new fone...I tried the Nokia Connectivity Cable Driver 6.80.5.1 thing but no luck. Can someone run me through all the steps of getting this to work?
get the latest nokia pc suite from nokia website, install and follow the
instructions. use the dku-2 cable not a problem, its automatically install
the new driver for dku-2 cable.
one more thing, please uninstall first the current version on your pc. then install with latest version.
previously i got the same problem and solved😊
