is it possible for jabrabt800 headset to show names with nokia 9300?
2 replies · 1,834 views · Started 16 June 2006
i have jabra BT800 headset, it shows only numbers in the caller id if used with nokia 9300 , is it possible to make it shows the name as well?
thanks
try to copy some numbers in to the sim Card.
Then go to Control Panel, Bluetooth-Select and then enable Remote Sim Access.
Then ask someone from your sim card memory to call you.
It might work, i dont-t know.
Let us know please 😉
