Remote Camera
24 replies · 3,915 views · Started 27 November 2002
Guys, the Remote Camera with Multi Image functionality is ready...you can try it out and tell me if it is ok in order to correct some bugs if there are any....I need some help with testing because I am developing further applications...Thanx
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3395
i've got V3.16 it takes the picture fine 😃 cant seem to get multiple images working though
i copied the command on the previous thread. should that work? :-?
[quote="sparty101"]i've got V3.16 it takes the picture fine 😃 cant seem to get multiple images working though
i copied the command on the previous thread. should that work? :-?[/quote]
Be sure to have the latst version installed.....Check if the first images is Remote0.jpg.......try to take pictures about 3-4 without the SMS...just go to options--->take picture....
P.S. for the SMS to work the program must be running in the background....
hey man i am still gettting the Kern error. I have installed the new version. My firmware is 3.12
Install Camera Timer to the phone two! There is a small detail that I have to correct still in a later release where I will combine the two....
[quote="MaleBuffy"][quote="sparty101"]i've got V3.16 it takes the picture fine 😃 cant seem to get multiple images working though
P.S. for the SMS to work the program must be running in the background....[/quote]
ive got the latest version installed and camera timer and have the program running it still only takes 1 picture
what should i be writing in the sms to get it to take more than 1 picture
thanks
Yes it still will take one pic per sms! But when you send 3 sms it will name the 3 pics with a different name! Next week I will have the full customised SMS version ready!
hei what what for this program called remote cam, what is the use and how it works, can somebody tell me please ??
i really have no idea :P
This program does the following....when run in the background it monitors the inbox! When a SMS arrives with the text //RECA in it it will take a picture so that you can take pictures remotely! For it to work there must be Camera Timer installed which can take pictures with a delay so that you can run up to your friends and be in the picture as well!
[quote="MaleBuffy"]This program does the following....when run in the background it monitors the inbox! When a SMS arrives with the text //RECA in it it will take a picture so that you can take pictures remotely! For it to work there must be Camera Timer installed which can take pictures with a delay so that you can run up to your friends and be in the picture as well![/quote]
wow, thats quite cool but the 7650 wont stand preoperly on it's feet aren't they ?? so what is the use ??
don't u afraid that it might fell off ??
Well this is up to you basicaly! If you switch off the vibra it wont fall off! 😊 However, this app is not intened to make a noise when the SMS is received anyways 😊
Is it posible to trigger the Hantro Video? maybe you could include it? Maybe you could make it remote control?
Why using SMS to trigger the remote carmea?!
It is possible to preset a tel.no and check the caller id to trigger the carmea!?
It is free for charge!!
[quote="MaleBuffy"]In order to do that I would need the Hantro Source code, which of course I dont have![/quote]
Is it possible then to make your program use the key strokes step by step. For instance, activate hantro, send key event to record etc...
How about...
Remote Cam...gprs, a server, delays, buffering, streaming video. Somehow it has to mimic the algorithm of the Hantro, using the fps. Now that's a great application.
Hey just a thought.
Another thing, make sure that the sent files are automatically deleted so as to free up space.
Lastly, is it possible to make the recorder to work as well, so that we would be video conferencing through GPRS.
Yahoo!
LOL, some of it is quite a bit off the actual appliction use! However, thanks for the points....I wont forget to delete the images 😊
Just shows excitement over 7650.
Imagine if we could have video phone out of it? Using an earphone, then focusing the camera at our face... The future!!!
Ok, way out of line...
Then again, why not?
Take for instance HANTRO, it saves the video into a file. SO that we would have a video. That's great. Now what if, each of thos frames are sent as packets through GPRS, onto another phone, then that's the idea.
[quote="deevonn"]
don't u afraid that it might fell off ??[/quote]
My 7650 stands up when open and closed, vibrating or not!
How can your phone be the same yet balanced differently??
[quote="tvoung"][quote="deevonn"]
How can your phone be the same yet balanced differently??[/quote]
If his/her battery is full, then there will be more electrons at the top of the phone, meaning that it will be heavier! 😉
Seriously... it kindo balances, but i'm not sure if i'd trust it enough to walk away and leave it standing like that... slightly too precarious...
