problem with my realplayer
7 replies · 1,735 views · Started 16 June 2006
my realplayer doesnt play mp4 format videos. how can i fix this problem. and if this is because of i might be using some other format then plz direct me.
i'll be waiting for a reply! thanx in advance..
This is probably because your MP4 is in a codec that is not support by Real Player.
Try SUPER which is freeware and available from http://www.erightsoft.com/SUPER.html
Settings:
Container: MP4
Video: MP4
Audio: AAC
Then video settings:
Aspect: 4:3
Frame/Sec: 15
Set the bitrate to 128, 144 or 196 (progressively bigger sizes).
As for audio use 44100 at 96kbps for audio enhanced, 22050 at 64kbps for standard.
ishfaqkk wrote:my realplayer doesnt play mp4 format videos. how can i fix this problem. and if this is because of i might be using some other format then plz direct me.
Just as an example of MP4 that I know your N70 will play, see my own Smartphones Show, at http://3lib.ukonline.co.uk/sshow/
Steve
thanx alot for ur replies.. thanx rafe the super software worked.
btw there are many more problems i face with my n70 mobile phone.
there is this camera which has worst resolutions than 6600 vga camera. and the bluetooth is like i send something by post (very slow transfer speed) i have to wait for minutes to send 2-3 mb file. at times my bluetooth cant be searched by other bt devices. has anybody else experienced this??
ishfaqkk wrote:thanx alot for ur replies.. thanx rafe the super software worked.
Eh? The N70 camera is superb. If your main camera isn't (post a picture here if you like), then you need to get it repaired. What resolution/quality do you have it set to?
Bluetooth is never very fast, 1 minute a MB doesn't sound too far wrong.
Steve Litchfield
i have set image quality to the print quality, but it still depends on how good the light is. .. how well u take the shot. i get good images only at 12 noon... otherwise i get blurred pics.
and for the blutooth i would say its really slow.. i have used 6600 7610 but this has got really slow speed. when i send a file to some other mobile, it takes double the time than what it takes to recieve the same file.
Try changing the file extension to .3gp I have to do that with some films downloaded from 3 UK use file manager or FExplorer
ishfaqkk wrote:i have set image quality to the print quality, but it still depends on how good the light is. .. how well u take the shot. i get good images only at 12 noon... otherwise i get blurred pics.
Aha. You're not allowing for shutter lag. In bright conditions, you can press the shutter and the picture will be taken in well under a second. In gloomier light, it can take well over a second, so YOU HAVE TO HOLD THE CAMERA STILL while the phone gathers light etc.
Steve
