After choosing a theme, it takes ages for the Themes application to actually close. Does anybody have any ideas as to why this should be?
The memory card seems to be Ok by the way (no errors or problems with it anywhere else)
Do you have many themes (a few? tens? hundreds?)? Does it close faster without the memory card in the phone (with only those themes that you have in phone memory)?
It takes just as long if I have one extra theme installed or fifteen.
Thanks for the reply 😊
Is it one particular theme. Could be it that it is a heavy theme and it takes longer to put the file in place? Could also be that theres an image in the theme that is corrupted or it doesn't like. That said I donn't think this is necessairly the answer. Bit weired actually!
