anyone having problems with the keypad light and how to fix it,
the light has gone out. how to replace and where to get the light unit.
thanks, earl
Keypad Light
You can alway sent in for repair or you can repair yourself
http://www.uselessinfo.pwp.blueyonder.co.uk/dismantle3230.htm
teach you how to open......
as for replace of part. you must have a replacement LED (SMT type) and a solder iron for removing and replace the working part in
all replacement without demaging your mobile is base on your soldering skill and luck.
