wanted apps
8 replies · 1,829 views · Started 27 November 2002
Doesn't webviewer view PDF files?
Not sure about offline viewing, but maybe you could add the PDF to directory and view by opening using a filemanager, I suppose that webviewer would have to be associated with that file.
If it doesn't associate it auto maybe that could be added for a future release.
... I'd love to see a shopping list utility... Something that you synchronise with your PC, your usual bits and bobs and other stuff you need from the supermarket, download the list to ur phone then as you wander around you can "tick off" the bits off on your phone...
Sounds like a neat idea 😃
for Shopping lists use HandyShopper, does not work exactly like you
suggested, no PC in between.
And WebViewer coverts the pdf on the server and converts it to html
there. so it wont work on the phone. but you can upload the pdf somewhere and then read it with WebViewer, + it saves the space on phone too 😃 😃
all i want is just a simple pogram to view words document offline!!! is it very difficult to create ??? c'mon developer.
London Tube Map app...
So you can search tube stations and plan journeys etc
Got one on my PPC, but on phone would be much better 😊
Mr G
id like a networking app which would let me create a serial connection between pc and phone without starting it on the pc. All from phone.
like bemused does, all you need to do with that is start the program and it connects to the pc.
what else..........erm..........c64 emulator is highest priority. There are source codes out there....frodo is one. A SID player for the phone as well.......again, source code is out there.
dammit....i wish i could program. Who can give me pointers for learning.......a good book to get? Good language to start with ?
Also, a bible for it would be good. Would need good compression though, its a big book!
