Hi.
If I run a app and close it with the red button does the app still run in the backgroumd.
If it does how do I close all running aps??
|Thanks
Gary
Hi.
|Thanks
Gary
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0611.0.8) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
hold the menu button down, all runing apps wil show in a list, highlite app and press c on it to close it!
Thanks.
Gary
The red button does close apps as well. You don't really need to worry though as the OS is intelligent enough to close applications if needed to free up memory automatically. In other words you don't have to worry about open / closing application as you do on other platforms.
