N91 Wlan
2 replies · 3,048 views · Started 18 June 2006
Yo peeps! Just need sum sort of guidance on setting up the Wireless LAN on my N91!?
I get a message sayin "No Gateway Reply"
Im using BT wireless broadband.. Ive enter'd all the settings i possible can..
Ne1 else come ascross any similar problems...!!?
Thanks!
Is your WLAN security protected. If so check you entered the information correctly when setting it up as an Access Point. Also if you have MAC filtering you would need to add your N91 to your allowed list (though I dont think BT broadband does this).
I'm afraid I dont have this particular combination so can't really help all that much.
