As far as I know we can delete all or nothing in Log Registry.I'm looking for a way to delete just one log entry and keep all others entries in Log Registry.
How can I delete just one entry in Log Register?
Inc
Inc
Try highlighting an entry in the Log app, and hit 'C' (or Options > Delete). Some older models (based on older S60 versions) might not support it, though.
N/A wrote:Try highlighting an entry in the Log app, and hit 'C' (or Options > Delete). Some older models (based on older S60 versions) might not support it, though.
It seems that doesn�t work in my phone.
Any other suggestion?
Thanks.
Download the N-Private application by 125 telecom. It will delete the number that you saved in that application in your log. Go to mobilesmania.
