N80 - Please post known 1GB & 2GB miniSD cards that are compatible please
30 replies · 10,794 views · Started 19 June 2006
Hi guys
N80 on order from Orange, should be with me tomorrow but I'd like to know which miniSD card to go for.
I fancy a 2GB card and was looking at the Sandisk cards on ebay for @ £30 but I am not sure if they're compatible. Some posts say yes and others say no. If the 2Gb cards are hit and miss I might have to plump for a 1GB instead.
Please post what you have had success with.
Cheers
Andy
I bought a 2gb mini SD card from here
http://www.mymemory.co.uk/Mini-SD
i got the MyMemory 2GB 133X PRO Mini SD
it is theoretically the fastest type available (or almost anyway)
seems to work fine, although i have nothing to compare it with. i never even used the 128 meg card that came with the phone.
Rob
edit,
see my later post about this memory
Zuma wrote:Hi,
Rob
Thanks Rob
I'd spotted that generic Mymemory card before but was unsure whether it would be OK. I have bought from www.mymemory.co.uk before because their prices are so competitive.
I will definately put this one to the top of the list for price and speed.
Cheers
Andy
personally I wouldn't buy a memory card off ebay again, every one I have bought in the past off ebay has been dodgy or unreliable...stick to an online established dealer like digimem or whoever. You'll get a card that works for a little bit more. My sandisk 1gb card bought from digimem works a treat
Hiya,
bought the following;
MobyMemory High-Speed 2GB mini-SD Card.
PRO 150X SLC miniSD memory card
www.mobymemory.com (~40ukp)
Got compability problems with my n80 & firmware (01) v3.0614.0.3.
Phones says corrupt mem card once and a while....
Pretty sure this is an issue with phone as on pc card works fine...
Will try new firmware soon, and post if it fixes anything...
ut.
I 've bought a mini SD SanDisk 1GB from Ebay and it works fine on the PC but when I insert it into the N80 it comes back with "memory card corrupted"
Can anybody advise what I should do?
Cheers
VJ
ut666 wrote:Hiya,
ut.
Bought the same, i have the new firmware (didn't flash) and no problems here. Very happy user 😊
bjarke wrote:Bought the same, i have the new firmware (didn't flash) and no problems here. Very happy user 😊
Mine is Kingston 1gb - works fine, very stable. lifetime warranty.
WARNING!!
I bought my SanDisk 1GB miniSD card of eBay for £25 and it was shipped from Hong Kong. The card works on my PC but when I connect it to the N80 it says 'memory card corrupted.' I've phoned SanDisk and they checked the serial number and said it was a fake and thats why it doesnt work in the phone. The card has correct SanDisk markings and a hologram at the back with serial starting with DAA.. SanDisk said the serial should start with BB.
Check this link out from eBay forum that talks a little more about it..
http://reviews.ebay.co.uk/Beware-FAKE-Sandisk-Cards_W0QQugidZ10000000001012646
i've got one of those 2gb sandisk cards off ebay, works perfect in my n80, i did get the 'memory card corrupted' message once but only because i reinserted it before pressing 'ok' and i just removed it and put it back in and all was fine, and if its a fake its a very good one
Just an update on the card i bought.
twice now it has stopped being detected by the phone. I had to reboot the phone to get it to be detected again. I didn't take it out and put it back in, just rebooted.
maybe it's a phone problem? I have the latest firmware.
so maybe don't get the memory i got, just to be on the safe side.
Also have the Sandisk 2Gb but my card doesn't work at all. The phone keeps displaying "no memory card" I do have the latest firmware. Bad luck.
I bought from this seller on MOnday I paid �30.99. How long did delivery take. Are these genuine Scandisk cards ?
Mem card arrived to-day 1 week from ordering it works in the phone perfectly and appears to be genuine. Im a happy bunny 😊
digicon wrote:£34.99 including Postage from hong kong did come in the official scandisk box with card adapter. And my PC sees it when connected to the PC with a card reader
and Here is The Link http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=9150454592&ssPageName=MERC_VIC_RSCKCK_Pr12_PcY_BID_Stores_IT
I only live 8 miles away from this seller's item location, I wonder if he'll knock the postage off if I collect? ....NOT! .....why oh why have postage @£10? don't see the point...it says he was member in Hong Kong, but item is from Preston?
I have asked the seller aquestion about total costs if I collect, he seems to have 2 GB Sandisk mini sd on Buy it now for £14.99 plus post......check out the ebay shop......I will let you all know the outcome.
Same as, with flashed new firmware. No problems. Happy bunny 😊
