WLAN Internet Browsing ERROR! HELP!
5 replies · 2,669 views · Started 20 June 2006
Hi, PLEASE HELP!
I have setup my wireless connection on my N80, I have given it an IP address and it connects fine. The problem comes when i try to access a web-site, I get an error saying "Web: No Gateway Reply".
If i try to access my routers cofiguration page (via http://192.168.1.1) it connects fine, so it is connecting???
I have taken all security off and it still does the same, i have now only put MAC-filtering on and still the same error.
HELP MEEEEEEEEEEEEEEEEEEEEEE!:frown:
Have you put the MAC of your device on the router. Check it is right by looking at the router admin - it seems some N80's report their MAC incorrectly.
One thing I have noticed with my N80 is if the wifi strength it detects is less than30 - 35 % I find it hard to connect and get the No gateway error, then when I check to see if its still connected it says no connection available, then after a minute the connection is showing again and the cycle continues
Quite frustrating
Hey burnsyboy.
you can access your local network but you can not access net.
make sure that in access point specifications on your phone, select advanced
and under advanced select IPv4 settings
you must define default gateway and DNS if possible.
i was just doing this today.
good luck
yesssssssssssssssssssssssss!
it works. i had set the default gateway but not the DNS, done it now and it works yay! cheers!
