Hey guys,
i have problems with some applications : ProfileExplorer and some kind of ProfiMail
these programs just crash whenever i start them! how do i delete them?
what should i do?
SECOND QUESTION:
how can i make my cellphone vibrate when i receive the txt message? 😊 i dont want the music to play, just vibrate...? 🙄
You delete/uninstall applications using the "Manager" (Application Manager) program in the phone menu. Details in the User's Guide of your phone.
You can change the message tone to an empty/silent tone.
N/A wrote:You delete/uninstall applications using the "Manager" (Application Manager) program in the phone menu. Details in the User's Guide of your phone.You can change the message tone to an empty/silent tone.
hey! thanks for your help!
i've managed to delete the damaged applications 😉
now for the second question...i've switched to silent mode, i've turned on the vibration and turned off the calling sound...but it vibrates only if someone calls...
You need to change the message alert to vibrate also I believe.
Wirelessly posted (Nokia3230/2.0 (5.0604.0) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
GrustnI wrote:Hey guys,i have problems with some applications : ProfileExplorer and some kind of ProfiMail
what should i do?
SECOND QUESTION:
You have to go profile and choose ringing type assending and keep vibrat elert on
You have to set your mmc card connect to pc and select folder system and go to libs.Than you can delete application
