Hi all , check this site out as you can upload your pics and it makes the theme for you ,so simple its in the beta stage at the mo but hurry as it will be gone soon and then you will have to pay ,Ive made loads, heres the link to the web sit
http://www.iguanamobile.com/main/
And the link to the theme making http://www.diysms.com/powertheme/s60v3/uploadphoto.jsp
You can get to it from the site just go to forum=support center=N80 Theme call for beta testing - FREE thats it ,if you find any bugs please report as this may keep it free for a bit longer , you can upload any pic you want :tongue: :icon14:
Free Theme making for N80 Quick
I cant get the red box to adjust size,Any1 else have this problem?
Yep same here.....cant resize red box:frown:
Using IE6 and it's working here.
Perhaps have a play with Java settings and see if that gets you anywhere?
Ta.
And how do we do this CO?
Errr..
Have a look under Tools -> Internet Options -> Advanced. There's an option in my settings which says 'Enable Java'. Maybe give that a try...
Ta.
Still no joy:icon13:
I know this sounds dense, but the first thing I tried to do was to drag the red box larger. Clicking and holding 'Bigger' ought to do the trick. If the app loads, I can't see that it's a Java problem you're facing. Hmmm..
Still no joy here either....I can move the red box around and change the colour and the XX% but cant make it bigger or smaller....If I put the red box over the pick it covers the buttons and I can click on any of them.....:frown:
OK...I was trying to use it on a GIF.....I have now tried it on a JPEG and works fine......Not sure why it wont work on a GIF thou...
It wont allow me to use Jpeg files:icon13:
Hi all , I have had no problums with it as i am useing me XP pics from my PC if you do have a problum go to the web site and post on the forum under forum=support center=N80 Theme call for beta testing - FREE !, also when you try to make a theme use a jpeg and wait for it to load fully on screen and then use the Bigger= Smaller keys to inlarge the pic and then click inside the red box and move it that should be it , then click next and you have the choose to add another pic or use the same one, click next and down load as an application loader and load it up to the phone , i stall mine on my sd card Hope this helps
. Remember to leave info on the forum to let the person know about any bugs and it may stay free for a bit more time 😉
Regards
Karl
Hi all, just to let you know this theme maker will be free till after the world cup so get making them themes :redface:
Regards 😮
Karl :tongue:
Hi BHOY,
May I know what browser (and its version) and OS you are using ? The porgram is not a java applet, it is just java script. So far it has only been tested on IE/FireFox in with MS Win.
BHOY wrote:It wont allow me to use Jpeg files:icon13:
Im using Internet explorer and windows xp:icon14:
Version? Check your IE: Tools->Internet Options->Security->Custom Level->Scripting->Active Scripting. Is this enabled?
BHOY wrote:Im using Internet explorer and windows xp:icon14:
