Hey guys i found a autolock program that works on my N80. Although it autolocks after 25 seconds minimum, it's better than the N80 default autolock done by minutes.
Check the attachment for the file.
Holla at your boy!
By chance anyone know where i can find a program that can auto-send me information where i lost my N80 if i lose it? I know that i've seen a program for it for Symbian S60 V2.
Thanks I will give it a go.
Gary
Seems to work well for me 😊
Works well for me to..Cheers
Pity it takes a bit to long to lock thou...ah well....
Is there any way to disable the N80's 'Lock Now' when you close the slide?
Installed today and its superb!
Highly recommended!!
Phoned numinous people last night while my phone was in my pocket.
THANKS!
mtb2002 wrote:Works well for me to..Cheers
Pity it takes a bit to long to lock thou...ah well....Is there any way to disable the N80's 'Lock Now' when you close the slide?
I think that can be done in Settings?
Just had a quick dig & I didnt manage to find anything obvious - any ideas where you saw it Rafe? :con?
BTW - you got PM.
I change my setting to 10sec.....
10sec is not long.....
Good software - would have been perfect if it also lock headset's button. keypad locked but headset button pressed against a book and it activated voice command and started calling
thanx a lot for the post..........
it is ia good software, i installed and working well.........
i works great..tx dude!! 😊
i installed auto lock software for my n73, unfortunately it locks only after 30 seconds even set for 10 sec...
any other way to set to 10 seconds ??????
thanx
