Is it possible to delete incoming call so as not be listed?
3 replies · 3,774 views · Started 21 June 2006
Hi
Is this possible :
An incoming call arrives and if it is a certain number, after the call
I want to delete this incoming entry so it will not be shown in incoming calls. And if it is possible I also want to edit this entry like changing the phone number.For the outgoing call same is valid.I want to delete this entry if it is a certain number so it wil not be listed after the call is finished.
Any help will be appreciated.
Regards.
[QUOTE=aykutucar]Hi
Is this possible :
I want to delete this incoming entry so it will not be shown in incoming calls. And if it is possible I also....QUOTE]
hey bud...
1... what's your phone model?
2... have you read the manual? I'm sure you'll find it there.
3... I wonder why you're needing it.
1- I m not sure but it is a s60 type
2-I dont think that a a very specific symbian programming issue will be listed in the manual.
3-I do not know my customer needs it.I ll just do it if I can.
regards
