N80 document folder sync?
6 replies · 2,469 views · Started 21 June 2006
Is there a folder sync application?
Can you create a document folder on the PC desktop and have that sync'd automatically with the phone?
I know I can do it manually but that is a pain.
thanks
It doesn't matter what prompted the developer to write it, but what it does is synchronize a directory with another on an USB device. It should work regardless of iTunes and what kind of device is connected (Nokia phone, Sony Ericsson phone, just an USB memory stick, or whatever).
I tried the massstor but it does not see the phone when connected via bluetooth, will try with the UDB tonight..
I have a folder (Transfer to N80) on my desktop (xp professional) and save any files I want on the phone to this folder. Web pages, emails etc.
I have created a batch file (Transfer_to_N80.bat) on my desktop that contains the following
xcopy "D:\folder structure to Desktop\Transfer to N80\*.*" F:\Documents /y /s /d
exit
Then I created a shedule to run this file every 15 minutes and every time I log on to my computer. )Schedules in the control panel)
So long as I have the phone connected using the USB in Data Cable mode the files will transfer.
I can also just manually run the batch file by double clicking it on my desktop.
simple!!!
