Is there a software i could use to connect to my 7650 via infrared and enter/edit down my contacts true my pc.. to speed up the typing?
have tryed with the software thats is included with the phone but did'nt find anywhere to do this..anyone??
😮ops:
😮ops:
you can sync with outlook...
then when you add a new entry in outlook and sync again it will be beamed to your phone.. thats the way i do it 😊
ok, i understand.. are there any updates for the pc suite (that came with the phone) availbel out there??
[quote="toggy"]Is there a software i could use to connect to my 7650 via infrared and enter/edit down my contacts true my pc.. to speed up the typing?
😮ops:[/quote]
No. You cant edit the contacts realtime on the phone thru the PC. Your best bet it to Sync after first making the changes/Edits in Outlook on pc. (This may not be an awsome way of doing for just one or two, but could help in editing multiple contacts at a time)
oki, thankes mate 😃 😃 ..
You can also send contacts as a vCard from Outlook contacts if you can't get PC Suite(Xp not compatible) working.
hope this helps
