What's the latest Firmware for the 7650 ? (my phone using 3.12, and are constantly locking, and restarts and using alot of batterys.. lol.. 😊
any of these sympthones been fixed?
The latest firmware depends on where you live, but 3.16 will (Should) be out everywhere, if not 4.14.
Yes most of the bugs mentioned should be fixed, if not all.
Isn't the latest firmware 4.37?
[quote="😊"]Isn't the latest firmware 4.37?[/quote]
Again, depends on where you live.
I live in the middle of nowhere!!!
[quote="😊"]I live in the middle of nowhere!!![/quote]
You'll probably be on 2.13b then (b = Beta)
i always forgot something! 😮ops: again, what is the code to see which software version you have?? 😮ops:
I'm in Norway... and i dont have a clue what firmware is availebel here...
[quote="Shadow"]i always forgot something! 😮ops: again, what is the code to see which software version you have?? 😮ops:[/quote]
*#0000# to check s/w version
*#06# to check IMEI
You type
*#0000#
AHHHH!!
Even Pichu has the speed reply button!
WHy mE?!
Checked today (in Norway at "Mobilverkstedet", Bergen) and they claimed the latest was 3.16
- K -
thanx!!
Mine is v3.12 made in Finland. From what i understand there is 2 types, made in China and Made in Finland. China sets has the Asian languages where else Finland sets has French and Deutsch.
Does anyone knows whether can i get it upgraded to v3.16 in Manila, Philippines?
lazzy. you can contact kenneth at 09178373718, his shop is located at telecom world ,robinsons place ermita.
thanks migueltan. tried calling him but no one picking up. will try later again. Are you on 3.16?
Got hold of Kenneth and he's charging Peso 1000.00 (~USD$20.00) for an upgrade to 3.16. I think it's too much, opinions?
Dont you have an NSC there? It should be free!
[quote="MaleBuffy"]Dont you have an NSC there? It should be free![/quote]
If your phone is under warranty and not off the back of a truck. 😉
Ah yes.....didnt think of that!
lazzy, try going to Semicon. if your phone is still within warranty, you can get the upgrade for free. Or else, they will charge around P550 for service.
Just had mine upgraded from 3.12 to 3.16 (tmobile UK) but there is a problem when going into general under phone settings, it comes back Error! General Settings
Any ideas? Bodged firmware upgrade? :x :evil: :cry:
i just had a home made upgrade to 4.37
so what's new in it 😊
home made upgrade??? how did you do that??
i used the flashing thingy
it looked ugly but i'll maneg
Should i get them to re-flash it, hard reset it??? Its just they are wanting to send it off to nokia for two weeks to be looked at whil i have a 5510 on loan, ive only has it 5 weeks!!!
[quote="henry"]Just had mine upgraded from 3.12 to 3.16 (tmobile UK) but there is a problem when going into general under phone settings, it comes back Error! General Settings
Any ideas? Bodged firmware upgrade? :x :evil: :cry:[/quote]
