Summary after call
2 replies · 2,300 views · Started 22 June 2006
Menu > Tools > Settings > Call > Summary after call
Based on the help it says: Select On to briefly display the approximate duration of the last call.
But even its on/off it doesn't seems to work on my E61, after every calls I didn't see any so called "approximate duration of the last call" or anything simillar.
Does anybody has the same problem? or am I not looking at the screen correctly?
-riannn
the settings that you use are the correct, if this function its on, you should see after a phone call (incoming and outgoing) a brief message saying the call duration, please try to put this funtcion as activated and off / on your phone to see what happends
vjleon11 wrote:the settings that you use are the correct, if this function its on, you should see after a phone call (incoming and outgoing) a brief message saying the call duration, please try to put this funtcion as activated and off / on your phone to see what happends
Try it.. done that... still not displaying.
I haven't figure a solution for it but found out what causes it. Its the Maxis sim card. I try switching one of my other sim card and the call duration summary appears after a call.
I have posted a thread about "Unable to send dial tone during calls" and found out that is the Maxis sim card problem as well. Went in to the Maxis customer service and they have no idea on solving it, but not big of a problem for me since I will only be using the card temporally.
-riannn
