Does any1 know of a firmware or application that can be used on the N80 that has an SMS counter?
1 simmiliar to this,
http://www.symbiangear.com/product.html?pid=14585,14589,59907
It is in MY OWN folder (I may have moved it though) called LOG. It gives you the call, gprs data but if you cursor right it goes to a detailed list that you can then filter. Not sure if it has a total or not but looks fairly detailed.
Sadly it only lists my calls and data,not txt msgs!..Inmo this is a big disadvantage and silly from nokia!
Well, if you go into your inbox/outbox and go into a message, you will see in the upper-right corner a number, such as "1/43" or "32/57". It means you are reading the latest message out of the 43 in your box, or 32nd out of your 57. There you will see how many messages you have gotten and sent! (Although for the outbox you have to set it yourself to save your messages, and maximum 999 (but you can save them to a folder before that...) can be saved)
At least it is something!
Thast great thanks very much,Could you tell me how i set my "sent" box to store the maximum amunt of txts that it can please?
BHOY wrote:Thast great thanks very much,Could you tell me how i set my "sent" box to store the maximum amunt of txts that it can please?
Thats great,thanks very much indeed:icon14:
