Hi All,
When i take a pic on my N80 (Orange UK) i get a little menu come up saying upload image and add to album. is there a way of gettin rid of this so that it just shows the image taken and you can just go to new image rather than saying no to this menu all the time. its really pissing me off. 😮
burnsyboy wrote:Hi All,When i take a pic on my N80 (Orange UK) i get a little menu come up saying upload image and add to album. is there a way of gettin rid of this so that it just shows the image taken and you can just go to new image rather than saying no to this menu all the time. its really pissing me off. 😮
There must be a way because I dont get that message, maybe its Orange specific
yes there is , you need to decline the license for teh photo app.(you can chose to exit it from ethoptions of the app itself) then it doesn't prompt you. Installing the latest firmware also removes it.
You can turn off the photography program in the photography application. There's an option in the settings "enable phography service" or something similar. I can't remember the exact name as I've flashed mine and it's since disappeared 😊
Can you give me a step by step account of disabling this feature as I seem to be a bit thick & cannot find any photography apps in my app manager.
I am on orange.
Cheers
Ok, Done it
My Own - Photography - Settings.
:icon14: hi,Im new to this forum and I have had the same problem as you with the image uploader,but thanks to you I have now fixed my problem too.Many thanks Martin.
