Hi.
When i use Wifi to read email or surf the web is there a way of turning the conection off when I have finished so it does not use the battery up.
I noticed that the little WFi sign stays in the window until i turn the phone off/on.
Gary
Hi.
Gary
connectivity/conection manager/active data connections/ select your connection
and select options and disconnect
El Presidente wrote:connectivity/conection manager/active data connections/ select your connection
Doesnt just pressing the red "end call" key when you have finished with wifi turn of wireless and send you back to the main screen.
thats what I have been doing to turn off the wifi connection.
The wifi Icon I have are 4 little squares, and when wifi is connected the squares are blocks, and when dissconnected the squares are borders
Cash wrote:Doesnt just pressing the red "end call" key when you have finished with wifi turn of wireless and send you back to the main screen.thats what I have been doing to turn off the wifi connection.
FANTASTIC!
and im going through 5 different screens every time.
Thanks mate.
El Presidente wrote:FANTASTIC!and im going through 5 different screens every time.
Thanks mate.
No probs 😊..the tips and tricks and info I have picked up from this forum is gold, and its a pleasure to share any info I can 😊
So it does..thanks
Gary
