I've had mine three days now and love it to bits - the only thing missing is a port to enable me to make love to it as I think it is that sexy.. but that's just me..
Erm..
:redface:
OK my only gripe is the sloppiness of the slider - is everyone else's the same or have I got a duff one? When closed, the screen part seems very rocky, it gives a mill or two each way as you waggle it.
Also, when shut it is not particularly secure. It tends to open at the slightest touch, when one-handedly powerning off it will slip apart or when it's in my pocket.
I can hold the phone by its screen and, when moving down sharply, can get the whole phone to open up by the weight of the phone alone - is that normal?
Drofidnas wrote:I've had mine three days now and love it to bits - the only thing missing is a port to enable me to make love to it as I think it is that sexy.. but that's just me.. Erm..
:redface:
take it back and get a replacement, it shouldnt be like that, my slider is solid as a rock, the screen does seem to slide open quite easy, especially when taking out of my pocket, I have gotten used to digging deep and hooking my hand under it now when I take it out of my pocket
Don't worry about it. They are nearly all like that. Everyone I know and that I have spoken to (and there are numerous threads here) have said there is play in the slider. Mine also opens if I hold the screen and shake it violently, although why you feel this is a valid test is byond me, unless you always hold your phone by the screen and jump up and down a lot.
I took mine back to the Orange shop and the other seven I looked at were all the same.
Simon
Woollie wrote:Don't worry about it. They are nearly all like that. Everyone I know and that I have spoken to (and there are numerous threads here) have said there is play in the slider. Mine also opens if I hold the screen and shake it violently, although why you feel this is a valid test is byond me, unless you always hold your phone by the screen and jump up and down a lot.I took mine back to the Orange shop and the other seven I looked at were all the same.
Simon
Maybe I am lucky, my slider is very tight and feels very solid and smooth to slide with no play at all 😊
Me and a friend got our N80s from Orange around the same time and my slider feels a lot stronger than his. His seems to open (and close) a lot easier than mine. I guess they're all slightly different!
Woollie wrote:Mine also opens if I hold the screen and shake it violently, although why you feel this is a valid test is byond me, unless you always hold your phone by the screen and jump up and down a lot.
I'd have thought some sort of mechanical latch, or an interference fit might have been better. I might try getting another to see.
And just now, it crashed on me giving the message "Unable to begin phone startup sequence. Return to your retailer"!!
I had to de-battery it but I've not has that one before - maybe it heard me talking about its sloppiness..
Cash wrote:take it back and get a replacement, it shouldnt be like that, my slider is solid as a rock, the screen does seem to slide open quite easy, especially when taking out of my pocket, I have gotten used to digging deep and hooking my hand under it now when I take it out of my pocket
Lol, mine is like urs, im happy for that we got lucky, wut color of N80 do u have guys?? mine is black =D
my phone is also like this. nice and solid and the slider has just the right amount of resitance to opening. even if i use a lot of force i can only get the screen part to move sideways about 1/5 of a millimeter.
_Dx_ wrote:Lol, mine is like urs, im happy for that we got lucky, wut color of N80 do u have guys?? mine is black =D
Silver, I didnt like the black..
Just found out how to make my slider tight and free from play - I replaced the silver cover with a black one I got from eBay and the phone is now rock solid.
Shame about the silver keys, but it looks cool in a weird way.
Simon
