Viewing System Files
2 replies · 4,109 views · Started 23 June 2006
You need to enable viewing on the system folder in the file manager. I believe you can do this under options.
Rafe wrote:You need to enable viewing on the system folder in the file manager. I believe you can do this under options.
It's actually 'Tools | Settings', just to be pedantic 8-)
It's also worth noting that the supplied version of Zip Manager will also let you look round the Z: drive, i.e. the ROM. There's a hack to File manager that lets it browse Z: as well, but I applied it a few years ago and File manager has been running at half speed ever since, so probably not recommended!
