Hi. i looked for something like this everywhere and coulnd't find it.
My headset stops working once i disconnect it from the phone. i can't reconnect again unless i turn it off and on.
i only had to do this once a week or so... but now i have to do it everytime i want use my headset.
lately i have re-pair them up after turning the phone off and on to be able to use it. but as soon as i disconnect it from the phone i can't reconnect it again unless i do what i mentioned above.
i tried with 5 different bt headsets and they all do the same thing. and i got so many things on my phone to format it...
any recomendations will be really appreciated...
thanks.
i have a 6630 and i face the same problem,i flashed the phone to a local nokia shop with the latest firmware but its the same..but its the first time am using
BT headset wiz 6630...i wonder if its the same case wiz other mobiles...:con?
ok... i'll try formating my phone. can someone just tell me how to hard reset (format) a 6682? i knew it once. i've read it here... now i can't find it anywhere...
thanks
1.Switch off mobile
2.key press button 3,button *,button green simultaneously and at same time power on the phone
latest phone dont show format screen but the format should be done if ur phone ask for new date,time,or city...
Before the format do a backup of phone internal memory to the card. After the format, just restore the things, and you don�t lose anything.
hi guys.
i tried formatting my phone and still no luck with my headset. it worked for a little bit then it died again.
i'm gonna format it again, but this time i'll format my 1gb mmc card as well.
i'll give it a try for half a day or so... then i'm gonna start installing all the programs i had on my memory card... then i'll let you guys know the results.
PS. THANKS for the format thing. 😊
ok... i've tried everything now... formated everything. didn't use my mmc card just in case. tried turning my phone off then on... tried the same thing with the bluetooth settings. tried repairing them up. still no luck
most of them work for the first 3 times. i've got the motorola h700. and i flip it open and close often. the first 3 times seems to wok fine... then it stops again.
can anyone tell me what else i can try to fix this thing?
thanks.
PS. i'm getting another 6682 soon. it's a new one with the box and everything. how much do you guys think i can get for it?
thanks.
