Come forward to fix my n80.......
5 replies · 2,635 views · Started 23 June 2006
Being newbie to n80 type phones having problems sorting my contact list and dictionary, my phone has software,
V 3.0614.0.1
31-03-2006
RM-92
NOKIA N80(11)
now,
(1) what software I can upgrade to? which can allow me to sort my contact list to show FIRST NAME FIRST and have english to english dictionary instead of english/chinese?
(2) Where to get updated software?
(3) and safest way to install the new software without loosing my data or killing the phone?
want to enjoy my new phone, which till now is causing a pain in the neck.
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
if u do a software update u will LOSE everything u put on phone!
Hiya,
1 - v3.0617.0.6, 3-5-2006, RM-92 is the latest.
Open contacts, go to options -> settings and then Name Display - set to First nm. Last nm.
2 - See the sticky in the root of the N80 forums - http://www.allaboutsymbian.com/forum//forum/thread/46864/
Don't forget - Search is your friend.
3 - As Biggzy rightfully said, a firmware update will wipe everything on your phone - I'd suggest syncing it with PC Suite or iSync first to make sure you've got another copy.
James 😊
In contacts, select the left softkey (options).
Near the bottom of the list is 'Settings'.
Select this and the only setting you can set it the order of contact names (which is what you are after).
Regarding firmware, I didn't loose any settings when I upgraded. I did backup my phone with PC Suite just to be safe, though, and would highly recommend doing so if you decide to upgrade.
Only upgrade if you are confident in doing so and can follow instructions to the letter! You could really damage your phone if you do it wrongly. It is far safer to get a Nokia Service Centre to do it for you!
