Problem sorted, finger trouble...
Caller ID
Mine doesn't work either, how did you fix it?
Could it be that my numbers all have +44 in them in my contacts as I travel quite a bit? Is the device not clever enough to realise this?
It just started working, didn't change anything, very strange indeed.
I have the same problem exept that it jams with only one person! I reprogramed it like 5 times, it refresh in the list, it works one time, then it goes!? The rest of my contact list works perfectly, any sugestions?
Ignition101 wrote:I have the same problem exept that it jams with only one person! I reprogramed it like 5 times, it refresh in the list, it works one time, then it goes!? The rest of my contact list works perfectly, any sugestions?
I had exactly this problem with my old 6600 (IIRC). The phone was confused because I had the same number listed for two different contacts - so it just showed the number, not a contact name. It's possible that this problem still exists under the latest S60.
HTH,
David
