A few weeks ago, I read that there was maybe a possibility of adapting something to our 9210 in order to have as a virator... I mean not the one to stick up in your... But the possibility of having the battery vibrate. One member has put a topic that was mentioning that one could put a very low base wav file, that made vibrate the phone. Does any one have a copy of this wave tone in order to share it with all of us ???
Thanks Regards & Filakia
Sam said... LOL
Thanks... Will blame it on the Ouzo Effect !!! Burp
Filakia
Yeah I said something like that didn't I, turns out the best effect is in the female vocal range, hence to get the note that'll make the phone shake most you'll be *really* annoying people around you.
BTW I found out by playing a rave tune, thought it was the bass, but was proven wrong after experimentation.
So it sounds like we need a vibrating battery after all
but it does not seem like there is one in development
The main problem is in one connector what may get disconnected with vibra.. (damn my english is good
).. anyway, if you know what i mean.. it may not be good idea
How about external vibra in pocket ?
you know those lightning/vibrating stuff..
JeP
why not a simple vibrator that clips to the bottom where the headset would, and use the feed for the headset to make the vibrator vibrate.... shouldn't be too complex or large then.
Roll on Bluetooth then I can have my phone in one pocket and vibrator in the other. Should balance me up a bit
If you put a nervous moth in with the battery, whenever the ring plays, it'll go ape and that should vibrate the phone.
Failing that, you could always use a grouchy bee.
