I put a password on my nokia 3250 on th microSD memory card and when I turn it off and after a while turn it on again the memory card is not anymore detected anyone could help me out...pls! If it needs to be formated its ok but how? using a memory card reader?
Urgent Help: I put a password on the memory of nokia 3250 memory card
You need to put the password in again. Use the memory application that you'll find under tools.
Well I decided to go to the service center in which my mobile is under warranty I let them check and they said there is a problem with the software and they reinstall the OS of my nokia 3250... thankssssss!
