Font Problem with Goodlink and E70
1 replies · 2,951 views · Started 24 June 2006
I have tested the 4.9.x (for my purposes) on the new E70. The application works great except the device seems not to have a needed FONT installed in the system. All of the fonts used in the email body is written in "blocks", however, most other fonts in Goodlink are working (ex email from, Good's menu). Good claims they support the E60 which has the same display and OS support as the E70 (http://www.europe.nokia.com/nokia/0,,77794,00.html?sw=1280). Does anyone know what font they use in GMM for the E60 device? Does anyone know what font is added or left out in E70?
That's strange. I wouldn't have thought there would be a different font. Unfortunately its a bit difficult to find out what fonts are / are not installed due to platform security in Symbian 9.
I'm not sure there's a lot you can do apart from trying to extract help from Good.
