problem implementing infrared
0 replies · 1,508 views · Started 24 June 2006
hi all,
i am sorry to post this topic here but i was helpless as i got no response from communications.
I have developed one application from the example provided in the sdk
I tried to connect with the infrared port but it gives me error - 21 means access denied.
I am connecting with my pc and i have infrared adapter which is configured at port COMM 1.
Now if i try to connect with comm 1 it gives me error 5 (operation requested is not supported)
if i try to connect at comm 0 it gives me error - 21 (access denied )
please help me to get out of this here is my code:
#if defined (__WINS__)
_LIT(PDD_NAME,"ECDRV"😉;
_LIT(LDD_NAME,"ECOMM"😉;
#else
_LIT(PDD_NAME,"EUART1"😉;
#endif
_LIT8(DATA_STRING,"Symbian OS infra red printing\n\r"😉;
LOCAL_C void Init();
// Do the example
LOCAL_C void doExampleL()
_LIT(KStatus0,"Connect to file server\n"😉;
_LIT(KStatus1,"Connect to comm server\n"😉;
_LIT(KStatus2,"Load IrCOMM.CSY\n"😉;
_LIT(KStatus3,"Open IrCOMM::0\n"😉;
_LIT(KStatus4,"Write to IrCOMM::0\n"😉;
_LIT(KStatus5,"Close IrCOMM::0\n"😉;
_LIT(KStatus6,"Close server connection\n"😉;
_LIT(KIrCOMM,"IrCOMM"😉;
_LIT(KIrCOMM0,"IrCOMM::0"😉;
const TTimeIntervalMicroSeconds32 KTimeOut(6000000);
//time-out value
console->Printf(KStatus0);
// force a link to the file server
// so that we're sure the loader
// will be present
RFs f;
User::LeaveIfError(f.Connect());
f.Close();
// Initialisation
Init();
RCommServ server;
// Connect to the comm server
console->Printf(KStatus1);
server.Connect();
// Load the IrCOMM comm module
// C32 will automatically search \System\Libs
// on all drives for IrCOMM.CSY
console->Printf(KStatus2);
TInt ret=server.LoadCommModule(KIrCOMM);
//test(ret==KErrNone);
User::LeaveIfError(ret);
RComm commPort;
// Open the IrCOMM port unit 0 (the only one supported)
// Open port in exclusive mode because we don't
// have any access control code.
console->Printf(KStatus3);
ret=commPort.Open(server,KIrCOMM0,ECommExclusive);
TRequestStatus status;
// Write to the IrCOMM port - the first write
// takes a long time as the IrDA connection is
// set up in response to this request. Subsequent
// writes to IrCOMM are very fast.
console->Printf(KStatus4);
commPort.Write(status,KTimeOut,DATA_STRING);
User::WaitForRequest(status);
//test(status.Int()==KErrNone);
User::LeaveIfError(status.Int());
// Close port
console->Printf(KStatus5);
commPort.Close();
console->Printf(KStatus6);
server.Close();
Please provide me some guidance ...
