Uploading files FROM 7650 TO PC via IRDA... How???
8 replies · 2,165 views · Started 28 November 2002
Please, help me. I bought the Chronos USB-IRDA adapter and have already connected it with my 7650 via PCSuite. But how can i upload some apps FROM my phone TO computer? For example, i have bought RallyX and downloaded it through WAP, now i need to free some space and to send this app. to my PC. How can i do it??? If i just use SeleQ and choose "Send" => "Via Infrared" it says: "Sending failed"... What's the problem, PLEASE help me...
disconnect your phone from PC suite. and wait for the ir to stop.
then send from phone. it should work that way.
Have you check on your PC whether you configured it to receive file? eg. you need to specify a directory to store received files 😃
i'm confused... 😞 i did that way... "Sending failed" But i can see that 7650 sends something because systray icon appears... Something is wrong.. i'm runnin' 3.16 with Russian language pack and WinMe... Maybe someone had the same problem?
maybe it is some software for PC like "SiemensSL45Explorer" for 7650 that can share files, isn't it?
WinME is known to problems. About the storage directory, i used to have a problem with that, give it a check if you want to 😊
[quote="lazzy"]whyismyspacebarnotworking? [/quote]
Damn! I had a long time to laugh so much!
Very good humor mate!
(Excuse me for being out of IrDA subject 😮ops: )
