hey here http://s60tips.com/ says that N80 has XPressMusic to synchronize music files with WMP but i cany get the option of Media player when i get the usb cable conected to my n80, i got the latest firmware and i dont have the option.
do anyone know wutz going on??? :con?
Yeah I think you'll find that in many of the production units the Media Player cable connection mode is disabled - mine certainly is (Orange UK 06) - dunno why - the pre-production one Rafe had had it and he seemed quite surprised when he found out mine didnt. 😞
You can put the phone is USB mass storage mode and use Windows Media Player sync that way.
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
rafe how do we sync with WMP using mass storage option? thanx
thx for the replies, but can we activate the xpressmusic option??, or how can i sync with WMP
WMP will sync with any USB Mass Storage device as far as I know (that how it works with the E61 anyway). Put the phone into USB Mass Storage Mode and then start WMP. If you to the Sync tab you should see your N80's memory card as the mounted device.
thanx il try it out in the morning
Using the data cable function works. Shows as a flash drive in WMP and syncs perfectly.
