ok, i got a big question, there are N80-1 and N80-3, wuts the diference with those devices :con?
u can find wich one u have behint the battery pack
The inclusion of the fact that the device will carry "WLAN" is interesting, because of the lack of such a description in the N80-3's test report. It's probably not really important, but perhaps Nokia refused to disable the WLAN functionality for Cingular (similar to how the WLAN is available in the HTC Tornado but disabled in Cingular's 2125) - and so the phone went from being listed on Cingular internal servers to ship from 21st Jan, to being cancelled.
Yes but the N80-1 has 2100mhz umts while the N80-3 has 1900mhz umts.
so wich one is better?
neither are better, depends on your location, if your in the usa, you'l want the 1900 umts. good luck finding that, but 3G is available in a very LIMITED number of areas, so no big deal until mayb late 07
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
n80-1 is european version and n80-3 is usa, the only dif is the UMTS band!
lmao, mine wont work on usa, that sux ill have to use GSM lol
