hi everyone I'm a new user love this site...
ok I've got
Data bearer GPRS
access point name😛ayandgo.02.co.uk
username: none (normally payandgo)
prompt password:no
password😛assword
authentication:normal
gateway ip address: 0.0.0.0
and then I try to connect to the web with web viewer it comes up with (status=-191 whats going on??? :-?
Welcome to the Forum!
You trying to connect through GPRS with your own settings??
GSM is cheaper through a pay as you go dial up account or you can try connecting thru ADSL by infra red or Blue Tooth with default GPRS settings.. search previous posts.. 😃
soooooooo how do I get it too work then??? 😊 😃 :-?
[quote="brock-g"]soooooooo how do I get it too work then??? 😊 😃 :-?[/quote]
what method are you using to connect?
GPRS (for GPRS settings you can get these from your Network operator)
BlueTooth
Infrared
GSM (dial up ) :roll:
gprs works fine so thats aready set up...
and for gprs internet to work with webview all you have to do is change the ip address to 0.0.0.0 right???or am I wrong.... :-?
Are you sure that you have GPRS data,
not GPRS WAP ??
hey guys, i'm having that same error "-191" what should I do?
i'm using GPRS. same settings as the first guy
If there is of French here, they can find the configurations of Webviewer for all the operators: Orange; SFR; and BouyguesTelecom on my site:
www.mobiledreams.fr.st
Ok guys. The answer for -191. Your Webviewer is fine, and making connection, but your GPRS is not configured for internet traffic.
The GPRS access point u are providing for Webviewer is only for WAP, which ofcourse wont work for any other kind of traffic, including Webviewer.
Resolution: Call your operator and obtain settings for access point for general traffic.
Goodluck 😃 😃
