can u help me chose ?????
12 replies · 2,724 views · Started 18 December 2002
Hi all ! Getting a new fone for xmass , and been reeden up. i realy like the 7650 from what iv read here, mainly for all the cool Applications and games , but the Panasonic GD87 and Sharp GX10 are much smaller and better looking . was woundering if ye could help me out ? I want a fone that i can mess around with and add to but size is also important? plezzz help . :roll:
Get 7650 or P800 or any SymbianOS phone. 😃
Great apps & games, good customisation options, and more.
Much better than those other options you got, with just java games 😞
Yes,the 7650 and the p800 are definitely better choices,the 3650 even.
Those devices that you have mantioned are no more then a regular mobile with colour screen.
You could almost call the 7650 a mobile computer! And buying any other non-symbian phone means your missing out on some great games and apps.
It very much depends on what you need more.
The P800 seems more of a Communicator-type device (PDA-centric), compared against the 7650, which seems more phone-centric (hence SmartPhone).
With the 7650, you'd operator it more like a phone, but with the P800, you'd be operating it more like a PDA. Keep in mind that the P800 has 2 advantages (at least for me) over the 7650: Bluetooth Headset profile support, and Memory Stick expansion capabilities. One of the biggest gripes I have with the 7650 is the VERY limited 3.5 MB of dynamic memory. Personally, I haven't yet figured out how it works out to 3.5 MB, but that's another thread. Last thing, the 7650 does WAP well, but Web browing isn't as hot, compared to what the P800 can do.
Personally, I have no need for another PDA, so I went for the 7650, which has since replaced my Nokia 8910.
It's going to have to be your choice, sicne you're going to have to refelect on your needs, and how you plan to use it. 😊
decide wheather you wanna go for looks or appz, the 7650 is one of the most superior phones on the market which is packed with things to do with it..... add ons etc... and is not that bad in the looks department. think of you needs and dont just go for what people tell you to get or what all friends have.
Well,the p800 has it all,really great design.Great OS.
If you want more of a showoff device,you know,for the girls,get the 7650. 😃
I haven't played with the P800 myself, but based on reviews, and my previous experience with ericssons. I think nokia might have a more user-friendly OS compared to Ericsson, from a phone point of view. From a PDA point of view, the P800 is probably better.
Compared with the other two phones mentioned, I think you need to decide if you want just a phone or something more.
[quote="GhostDog"]Well,the p800 has it all,really great design.Great OS.
If you want more of a showoff device,you know,for the girls,get the 7650. 😃[/quote]
Haha!!! 😃 i think it all boils down to this! 8)
Both of them have advantages over the other. Your problem is, 6 months from now, there will be a better new phone.
One thing sure about these toys though, "Batteries are included" 😃
