Problmes with Office suite
4 replies · 2,541 views · Started 25 June 2006
1.Word Processor
Sometimes after reopening a saved document, the fonts became "blocks". This happens when I save a .doc into a .txt. Sometimes it's a mix of "blocks" and normal characters even when I started editing it as .doc.
2.Worksheets
When I open a transferred worksheet (.xls) from the PC, the spacing became very small. The cell heights are smaller than the font size and I could not read them.
I try to adjust the row height but I would have to do it cell by cell. Making a selection of cells will hide the row/column height/width menu. Is there a way to do this at row/column level?
I find these 2 issues very annoying. Please advise.
Regards,
Mark
I found the cause.
1. It was QuickOffice. After I uninstall it, the problem went away.
2. Still no way to size all the rows (height) at one go. workaround was to reduce the font size.
I haven't seent these problems but wanted to say thanks for letting us know your solution.
Hi Mark, i got the same problem, did u find a solution,, i tried to change the fonts from timesnewroman to arial and it worked, try it ,, and plz let me know if there is any other solution.
ueseven wrote:Hi,
1.Word Processor
2.Worksheets
Regards,
Mark
kartik7k wrote:Hi Mark, i got the same problem, did u find a solution,
Yes he did, try reading the second post in this thread. 😊
