Not enough space to install stuff after IR beam
3 replies · 3,313 views · Started 28 November 2002
I have this problem with lack of space on the phone.
I usually use IR to send apps like Mobipocket etc to the phone, and it ends up in the Messages - Inbox.
This obviously takes up space, and you need a similar amount of space to install the file.
I guess my question is how do i install something in my Message box with less than the amount of space i need?
Can I eg, use seleq to move the file from /message or /mss to /app?
Btw, this came up when I was trying to install Doom. having beamed all the files to the phone which took up 1.6mb or so, i didn't have enuff space left to install , which would have taken up another 1.6mb.
[quote="ultraman"]I have this problem with lack of space on the phone.
Btw, this came up when I was trying to install Doom. having beamed all the files to the phone which took up 1.6mb or so, i didn't have enuff space left to install , which would have taken up another 1.6mb.[/quote]
If you have an open PC Suite connection, you can just double-click on a .sis in Windows and it'll install the app
