Just tried to install Adobe A, for example from this link I found on the forum:
http://www.nokia-asia.com/nokia/0,,91844,00.html
I am installing over the air but I get the error
"Installation of Signed application adobe_xxxx not supported"?
I have turned off all signing checks so what am I doing wrong 😞
Thanks!
JK
Yes. I found this as I first attempted to install it over WiFi and got the same. Downloaded it to the PC and copied the SIS file to the E61 and launched, installed sweet as a nut. Must be some quirk at the other end, I guess. Though you'd have thought Nokia would be on top. Well, perhaps not 😊
Tim
Sounds like Nokia may have a mime type set incorrecrtly on thier site. Generally if it doesn't work try copying to the phone as it has the fewest number of step to go throught then.
