Can I delete WLAN access points from N80?
2 replies · 4,991 views · Started 26 June 2006
I have entered the same one twice but cannot see how to delete one of them.
Is it possible once a wireless connection has been accepted by the N80 to remove it?
If so where is the menu...........:con?
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
goto settings/connection/access points then hilight u 1 u dnt want and then select options/delete!
