voice command startup?
1 replies · 2,270 views · Started 26 June 2006
Hello,
Is there a way to issue a voice command without hitting the voice command button on the phone? (nokia 6682)
I have seen some other phones were you could speak a "special word" that would replace pressing the button on phone to start voice command functions and I was wondering if there was a way to do it on the 6682 either through the phone or bluetooth headset or software?
thanks Kevin
Nokia 6682
You can by intalling the third party application called power dictaphone. By running the application in your phone, the program will go on standby & monitor the commands that you set in the application. Try searching for it in crazy4mobilez.
