Accessing pc content over wifi or internet like ultravnc?
5 replies · 3,853 views · Started 26 June 2006
Hi all, great forum and discussions im addicted!!
Is there a client or application like ultra vnc that i can use to access and control my pc remotely?
any links, suggestions most appreciated
Simplecenter, on the cd with the phone or Orb.com.
I am trying to stream from my computer to phone and vice versa via WLAN.
Downloaded some bbc stuff via real player on wlan, but can't seem to stream from computer to phone, comes up with gateway issue. When it works i can control my pc with the n80, on the home network setup.
james doolin wrote:Simplecenter, on the cd with the phone or Orb.com.
what firmware are you using ?
v 3.0614.0.3
went over to Orb. Works a treat on my own wi fi.
Wont transfer/stream I-tunes, however. I bought some Itunes music, burned to cd, put it onto nokia music manager and transferred to my n80 m/c.works a treat. It turned a Quicktime clip to a real player accessible clip easy enough.
however it would be useful to access my pc files at times, using simplecentre...however for the times i would potentially do it it probably isn't worth it. But any tips would be appreciated.
Would orb work to its full potential if I accessed it on another wifi setup e.g in a cafe/pub and my laptop at home was turned off. Or do I have to leave the home pc on all the time to access its contents?
james
For remotely controlling the PC from my N80 via WLan I use either:
- Remote Desktop from TS Mobile - http://www.tsmobiles.com/
- VNC - not sure of a link
Remote Desktop from TS is great. I'll probably get round to buying it but the Trial version is so great I've not been hindered enough yet.
Neil
