Can this be downloaded onto the fone?
There are a few clips on the net that i would like on my fone,when i view them on my PC they are opend and viewed on Media Player,When i try and send them to my fone they wont open.
This is 1 of the videos i sent and tried to open,but sadly it never worked:frown:
http://videos.lugdu1993.com/Marseille_Lyon
Or will these type of videos not work on the n80?
Appologies if this all seems dumb,but i dont have a clue when it comes to fones lol😎 :tongue:
u need to rip it to mp4 or 3gpp, u can use smartmovie too
If you do a search on this forum you should find quite a bit of information about converting videos so they are usable on your phone. You can not install WMP, but there is software on the phone that can play videos.
_Dx_ wrote:u need to rip it to mp4 or 3gpp, u can use smartmovie too
How do i rip them? Whats Smartmovie?Do i download it?
Regards
Rafe wrote:If you do a search on this forum you should find quite a bit of information about converting videos so they are usable on your phone. You can not install WMP, but there is software on the phone that can play videos.
I had a look there,nothing i can see relating to the N80:frown:
