Themes
2 replies · 1,317 views · Started 27 June 2006
Hi all,
I downloaded a world cup theme and when I applied it to my mob, the font changed and some msgs where deleted. I tried to apply back one of default themes but the font did not change nor msgs appeared back!!! I restarted the phone but no use!
Any help (some code to reset the phone's original settings) Plz reply.
Samah.
Changing a theme can not delete sms messages. It sounds like you installed a font too. You should use font remover to get rid of this (try a Google search / search on the forums for a URL).
Other than you can reset the phone, but you would lose your data.
I installed fontremover from the forum but it didn't work on my phone and I can't find the font file which was downloaded with the theme to remove it.
