The Best - N80 or N91
2 replies · 2,622 views · Started 27 June 2006
All,
I am on the verge of upgrading to an N80, however after seeing and playing with my flatmates, i'm torn between the N80 or maybe the N91 now..
I found the buttons too flimsy on the N80, though not had a play with the N91 to compare..
Anyone got or played with an N91 ?
Cheers
fmlad2002 wrote:All,
Cheers
I was originally going for the N91 purley because of the 4gig hard drive, but when I went to the shop to look at both N80 and N91 I decided N80 was better,
The keypad on the N80 was a little easier to use, its small, although a little thicker, I think it looks better and as I can use upto 2 Gb mem cards I find this more flexible and quite enough, especially as I have 2 of these cards.
And of course the N91 doesn't have a second camera for video calls
The hard drive put me off straight away, don't know what kind of battery the phone has but battery life could be poor and how fragile will it be with a hard drive in it. Not to mention heat or weight.
Still it looks a smart phone and I have not actually held one.
Those that want a better camera and an mp3 player. If you want either of those and want good ones then buy a task specific device. There are so many phones out there as we all have our own taste and requirements. I tried an N70 and a 6280 before I settled on the N80
