I was curious if anybody was successfully able to use the IM application on the N80, Can you use some kind of yamigo/wireless village server to connect to it? If anybody got connected with the IM application somehow, please list the settings you used, thanks.
anybody get the IM working?
cbcharlie wrote:I was curious if anybody was successfully able to use the IM application on the N80, Can you use some kind of yamigo/wireless village server to connect to it? If anybody got connected with the IM application somehow, please list the settings you used, thanks.
Do a search for IM, there already is a thread here that has dealt with this issue.
Quick answer: It depends on settings from your operator. If they dont support it, it will not work.
Cash wrote:Do a search for IM, there already is a thread here that has dealt with this issue.
you can't do a search for IM, its to short, and even if it wasnt, itd bring up almost every thread. Thats why i created this thread, impossible to sort through them to find the 'IM' im looking for.
cbcharlie wrote:you can't do a search for IM, its to short, and even if it wasnt, itd bring up almost every thread. Thats why i created this thread, impossible to sort through them to find the 'IM' im looking for.
try using a differnt search string like "instant" or " instant im"..but I understand what you are saying .
Try a Java apps. In N70 they work, but is OS8.x. In N80 I�m not sure. See here: http://www.getjar.com/software/ (legal download site with lot of Java apps).
You can use a service like Yamigo (i.e. it has to be one that supports the Wireless Village protocol). However for most people it will be eaiser to use something like Agile Messeneger (www.agilemobile.com), IM+ (www.shapesolutions.de) or eMSN.
Rafe wrote:Quick answer: It depends on settings from your operator. If they dont support it, it will not work.
It's not working for me and I've only tried via wifi to my router, that has nothing to do with my service provider.
