how to install software (n3250)
2 replies · 3,553 views · Started 28 June 2006
i
i wanna install games/software and i dont know how..
nokia have this 'barrel' effect that doesnt allow installing anything..
when i connect to the phone via USB cable under Data Transfer, i dunno where
to put the files.. there's too much folder and complicated..
freddy manson wrote: i
Er... why are you using 'Data Transfer'??? Select 'PC Suite' as normal (when plugging in the cable) and you'll be able to double-click on SIS installation files like the rest of us. 8-)
No need to know about folders.....
Steve
If you have PC Suite installed you can simple double click on the sis install file and it will be installed (provided your phone is connected). If you have not installed PC Suite you can copy the sis / jar files to your phone using the USB cable and Data Transfer. Copy the file to somewhere on the memory card (e.g. D:/documents/). On the phone go to the file manager, locate the file and open the relevant sis file - your install will start automatically.
